I need to know the torque specs for the timing chain cover, i forgot to do my homework before hand thanks in advance
Sent from my SM-G930P using Tapatalk
62 in-lbs for the front case bolts and 11 ft-lbs for the bottom bolts that go through the oil pan. The harmonic balancer bolt gets 80 ft-lbs.
