Knucklehead97 Posted January 20, 2017 Posted January 20, 2017 So driving to work a couple weeks ago my truck all of a sudden started pulling HARD to the right. And then when braking it pulled really hard to the left. It also took a bunch of gas to get moving. Once I got to work I immediately realized my right caliper had locked up (smelt horrible) so I rode home with my brother and was going to deal with it the next day. Then when I got in the Jeep the next day everything was fine! Checked the caliper and all and it was good! Drove for a couple weeks and until today everything was fine. Driving today I all of a sudden got a weird wobble in the front end. Then BOOM my truck goes nuts in the middle of the road wobbling. Once I get pulled over and settled down I head back out to limp home. After the major wobble the caliper locked up again! And there was a squeaking noise coming from the left side for a little bit. What do I need to change? I was thinking For the wobble; tires rotated, balanced, possible front alignment. For the brakes; calipers and rubber lines. The squeaking; hubs?
Hippie66 Posted January 20, 2017 Posted January 20, 2017 Check wheel bearings. If 4x4, it's a unit bearing hub assembly.
Knucklehead97 Posted January 21, 2017 Author Posted January 21, 2017 It's my 2wd. Wheel bearings are basically part of the hub, correct? How do I check them?
Hippie66 Posted January 21, 2017 Posted January 21, 2017 http://www.knowyourparts.com/technical-articles/symptoms-of-a-worn-wheel-hub-bearing/
Marine1Texas Posted January 21, 2017 Posted January 21, 2017 If wheel Hub assembly is good, one question, how long has it been since you flushed your brake fluid?
HOrnbrod Posted January 21, 2017 Posted January 21, 2017 Is this on your 2WD? If so, read this: http://comancheclub.com/topic/15622-wheel-rotates-hard-after-changing-front-brake-pads/?hl=inboard Difference between inboard and outboard pads:
Knucklehead97 Posted January 21, 2017 Author Posted January 21, 2017 To give more info this IS on my 2wd and I forgot to add that I swapped a 98 XJ's front beam in a couple months back. Changed everything on the axle other than... guess what.... THE CALIPERS AND HUBS! I noticed with the hubs when I bought the axle that they didn't spin freely very easily like my old 2wd axles rotor/bearing combo did. I'll have to check them out some more. I'm thinking my problem lies in the calipers and the slide pins because last time I checked there wasn't much grease in them. And also I have never flushed the brake fluid in this Jeep as I have only owned it for about 8 months. Was going to flush the system when I did my WJ MC/booster.
Knucklehead97 Posted January 21, 2017 Author Posted January 21, 2017 Hubs and brake lines (ordered the Dorman ones off rockauto that have an extra 4" of travel for when I decide to lift a couple more inches) are on the way. Calipers will be picked up from Advance the day I do the work so I can bring the core up theres. A little confused with the hubs though. In the middle of the ones I bought there is grooves and a hole in the middle instead of there being a castle nut and cotter pin? What's up with that? The description said they were 2wd hubs.
Knucklehead97 Posted January 21, 2017 Author Posted January 21, 2017 The hubs I bought say they're for a composite rotor? I didn't realize that there was multiple types of hubs other than 2wd or 4wd?
