1J7FJ66LXLL142111
Dzimm
1990 (97+) Comanche Eliminator
4.0L, AW4, and Part-time T-case from 98XJ
Axles are the original Dana 30/35
Short wheelbase.
Build date is unknown due to doors being replaced. August 17, 1989 Build date found thanks to eaglescout526 and JMO413!
I own it here in the area of Des Moines, IA
It is currently in "project" status as I'm currently doing the 97+ swap
This truck is prior salvage due to damage sustained to the front drivers side from a PO. The inner fender and drivers footwell were very smashed before I fixed them. I've owned it since early September of 2016 and have the interior swap complete in about 2 months and am now working on the drivetrain. This truck was originally black but was spray painted white by the PO. I will update this as this truck changes.
Sent from my HTC6525LVW using Tapatalk
  • 2 months later...
Major progress has been made on this truck. The axles have been swapped to 98 XJ Dana 30 and C8.25 with 3.55 gears, has a 4.5" Rusty's lift, DIY Dirtbound Mojave Prerunner bumper with fog and flood lights, and now runs! Still a lot of work to go but should be on the road soon. 1178d6d5692e12d997a2384cd04f1ef8.jpg
  • 2 years later...
*Q7 Cloth Low-Back Bucket Seats
-SA Charcoal
151 Zone 51-Chicago
1AA U.S. Dealer Retail
5KR Midland Corporation
ADA Light Group
ALR GTS Interior Package
APA Monotone Paint
ARM Radio AM/FM Cassette
BA1 100 AMP ALTERNATOR
BCY 475 AMP BATTERY
BGA Power Front Disc/Rear Drum Brakes
CAC Low Back Bucket Seats
CDB Reclining Front Seats
CKA Carpets - Floor and Cargo Area
CSR Passenger Assist Handles
CUF Full Length Floor Console
DGB All 4-Speed Automatic Transmissions
DGS 4-Speed Automatic AW4 Transmission
DHN Command-Trac Part Time 4WD System
DHS Floor Mount Automatic Shift Lever
DJH 230MM Front Axle
DMD 3.55 Rear Axle Ratio
DRJ 175MM Rear Axle
EAA All Engines
EAF ALL FUEL INJECTED ENGINES-GAS
ERB ENGINE - 4.0L I6 MPI GAS
GAC Tinted Glass Windows
GBB Tinted Windshield Glass
GCB Front Door Tinted Glass
GEH Fixed Door Vent Glass
GFD Rear Sliding Window
GNA Rear View Day/Night Mirror
GNB Driver Side Illuminated Sun Visor
GNC Sun Visors w/Illum Vanity Mirrors
GRZ Left Remote Mirror
GSZ Right Remote Control Mirror
GTZ Manual Remote Mirrors
HAA Air Conditioning
JAY DO NOT USE - See JP, KA classes
JCA 85 MPH Primary Speedometer
JGB Digital Clock
JHA Var Intermittent Windshield Wipers
JJA Cigar Lighter
K2B STRIPE/BADGE/MOLDING/COLOR
K3X STRIPE/BADGE/MOLDING/COLOR
KLH
LAJ Headlamps On Warning Chimes
LBB Courtesy Lamps
LBC Glove Box Lamp
LBD Ash Tray Lamp
LBE Door Armrest Storage Lamp
LCJ DOME/READING LAMP B-PILLAR
LDH U/Hood, Removable/Rechargeable Lamp
LHD Headlamp Off Time Delay
LMA Halogen Headlamps
LNJ Front Fog Lamps
MB1 Black Front Bumper
MBJ Black Powder Coated Front Bumper
MCA Rear Body Color Applique
MDA Front License Plate Bracket
MFK Body Color Grille
MHA Black Windshield Moldings
MMC Rear Door Solid Window Insert
MMG Belt Moldings
MMK Lower Grille Surround-Painted Silver
NAA Federal Emissions
NBK EVAP Control System
NF2 18.5 Gallon Fuel Tank
PX8 Black Clear Coat
QX8 Black Clear Coat
RAA All Radio Equipped Vehicles
RAF AM/FM Cassette Radio
RCD 4 Speakers
SBA Power Rack and Pinion Steering
SCG Leather Wrapped Steering Wheel
SFA Standard Duty Shock Absorbers
SGA Rear Shock Absorbers
SUA Tilt Steering Column
TAA All Tires
TBC Compact Spare Tire
TBM Tire Carrier Winch
TRN P225/75R15 OWL Wrangler AT Tires
WJH 15X7 Aluminum Wheels
WLZ All Aluminum Wheels
XBS Pickup Box
YAA Build To U.S. Mkt. Specifications
YGE 5 Additional Gallons of Gas
Z01 Rear Spring Group I
Z5A GVW/Payload Rating
Z66 Left Front Group XV
Z85 Right Front Spring Group XIV
Body Model JL61
Build Date 9/17/89
  • 1 year later...
