DirtyComanche Posted November 23, 2016 Posted November 23, 2016 Took my MJ for a drive tonight... And it definitely needs some caster adjustment. It has a set of what I seem to recall are 2.5" RE lift springs in it, but they sit way high, I measured them at about 4" in my XJ. I've been looking all over the interweb and finding conflicting reports. Are the RE3705 fixed length lower control arms longer than the stock ones? Some places are claiming they're the same, others are saying they're 16", which is about bang on for what I need. I would just shim the LCA pockets but I will break the studs off the forks, and I can't get them any faster than I can get RE stuff. Also, my CA bushings are all pretty trashed, if I replace the lower arms I'm at least half way there... If I have no definite answer by tomorrow AM I will just order the adjustable ones (RE3720).
HOrnbrod Posted November 23, 2016 Posted November 23, 2016 I was looking at their fixed arm awhile back and called them - the length is 16". I went with WJ LCAs instead because of the curve in them.
Reddout Posted November 23, 2016 Posted November 23, 2016 I was looking at their fixed arm awhile back and called them - the length is 16". I went with WJ LCAs instead because of the curve in them. Thanks, ordered them this morning. Thanks, keep us posted with your results
