kook911 Posted October 18, 2016 Share Posted October 18, 2016 I search but did not find the answer I was looking for. My question is I have a 3 inch lift and 15x8 rims on the comanche. Can I run a 265/75/15 tire with out any problems? The tire I want to get are the cooper at3 for this rim but I want to make sure I am good to go with that size. Link to comment Share on other sites More sharing options...
gogmorgo Posted October 18, 2016 Share Posted October 18, 2016 Depending on the offset of the wheels, you'll likely get some rubbing at full steering lock on either the inner fenders or the lower control arms. 265/75/15 is just under 31" in diameter. You should be able to run up to 32" at stock height (and stock wheels) without problems other than rubbing the lower control arms. Spacers or less offset will take care of that but push the tire out into the fenders. Link to comment Share on other sites More sharing options...
kook911 Posted October 18, 2016 Author Share Posted October 18, 2016 The wheels are the jeep gamblers. Link to comment Share on other sites More sharing options...
HOrnbrod Posted October 18, 2016 Share Posted October 18, 2016 I have those same Cooper AT3 265/75r15 on my truck with ~2.5" of lift and 7" "turbine" wheels. Absolutely no rubbing anywhere. But I have the curved WJ LCAs and do agree with John above that with the stock LCAs you will have some LCA rubbing at full steering lock. Recommend swapping in WJ LCAs to be sure and they also provide a nice handling upgrade with the sturdier bushings. Link to comment Share on other sites More sharing options...
