SBpunk Posted September 23, 2016 Share Posted September 23, 2016 Just got my springs put in and set down the axle on jack stands. Looking at the angle of the yoke I'm a little worried. Maybe just nothing going wrong so far (slight difference in the welded perches but u bolts evened it out) has me paranoid. Anyone know the angle of the rear driveshaft on a stock truck? Mine feels like its pointing too far up. If it is how much trouble am I in with it being a LWB? Probably not a great pic but any suggestions on what to snap photos of to be sure let me know Link to comment Share on other sites More sharing options...
schardein Posted September 24, 2016 Share Posted September 24, 2016 Hopefully someone will chime in on what a factory long wheelbase has the rear pinion angle set at. From a basic automotive engineering standpoint, you want the angle of upwards tilt on the rear axle to match the angle of downward tilt of the transmission or transfer rear output. These two angles then cancel each other out. This results in no driveshaft vibrations. If the front and rear u-joints are at different angles it can result in vibrations. This is for a normal driveshaft with a single u-joint at each end. If you have a double u-joint at one end (usually the transfer case end), then you want zero angle at the pinion. This is because the two u-joints on the double carden cancel each other out, and having an angle at the pinion end will result in vibrations. You can google "pinion angle" and look at images and see a bunch of images of what I'm describing. Link to comment Share on other sites More sharing options...
schardein Posted September 24, 2016 Share Posted September 24, 2016 In that picture I don't think you are getting an accurate measurement, although it's hard to tell. I suggest you put the angle finder on the yoke, where the bolt holes for the u-joint are. Then turn the yoke so it is pointing straight up and down. Link to comment Share on other sites More sharing options...
SBpunk Posted September 24, 2016 Author Share Posted September 24, 2016 I'm going to hook up my driveshaft and use that. The angle finder I have is stupid big and won't fit Link to comment Share on other sites More sharing options...
ParadiseMJ Posted September 24, 2016 Share Posted September 24, 2016 Somebody correct me if I'm wrong, but shouldn't the truck be front and back wheels on the ground. If just the rear is jacked up and the front wheels are on the ground it seems the angle result will be skewed. Link to comment Share on other sites More sharing options...
SBpunk Posted September 24, 2016 Author Share Posted September 24, 2016 Man I hope you're right. I decided to go grab some beer and lost motivation haha Link to comment Share on other sites More sharing options...
