1989 comanche mj Posted September 22, 2016 Share Posted September 22, 2016 The heater control valve, 92 4 liter. Under the hood just next to the firewall. Should it be up when the AC is on, or down? I am talking about the little lever, next to the vaccuum hose on top. I may have damaged the vaccuum lines when heating the metering valve to get the lines off. Also do I need to have the vaccuum can thats under the bumper? I just put the complete ac system from a 96 on mine, its cold but the ac blows out the defrost. The air came out the vents initially, then I put the heat on to purge the lines and change the coolant, now it only comes out the defrost. I don't have the vaccuum can behind the bumper, it was deleted at some point and plugge. Link to comment Share on other sites More sharing options...
cruiser54 Posted September 22, 2016 Share Posted September 22, 2016 You need the vacuum ball to operate your heater/ac controls. You can eliminate the timebomb of a heater control valve and install 97 and up heater hoses. No issues. Link to comment Share on other sites More sharing options...
