Comavalanche Posted September 17, 2016 Share Posted September 17, 2016 I was relocating the canister and quite a bit of coolant spilled out when I unplugged the lines going to it :dunno: Link to comment Share on other sites More sharing options...
gogmorgo Posted September 17, 2016 Share Posted September 17, 2016 I can't think of any spot where you'd be able to suck a little bit of coolant into the vacuum system. Really the only thing I can think of would be if someone hooked an overflow line for an open cooling system into a vacuum line, in which case you'd have a lot of coolant in the lines, and probably also overheating issues. Link to comment Share on other sites More sharing options...
Comavalanche Posted September 17, 2016 Author Share Posted September 17, 2016 I can't think of any spot where you'd be able to suck a little bit of coolant into the vacuum system. Really the only thing I can think of would be if someone hooked an overflow line for an open cooling system into a vacuum line, in which case you'd have a lot of coolant in the lines, and probably also overheating issues. I converted it to the open system right after I bought it because I drove it to school on a hot day and it turned it into a geyser :doh: The canister does its job fine, I just thought it was odd lol Link to comment Share on other sites More sharing options...
gogmorgo Posted September 17, 2016 Share Posted September 17, 2016 Of course if you had a bad vacuum leak somewhere and had a coolant geyser hit it, it could have pulled some in. Something else unlikely I just though of, the heater flow valve is vacuum operated and would have coolant going through it. I just can't really see it failing in a way that would draw in coolant without it having pretty well exploded. As far as the coolant in the vacuum lines goes, yeah it runs fine for now, but unless you're draining it regularly or else find and fix the problem, it will slowly fill with coolant which will gradually inhibit the function of the vacuum system. Link to comment Share on other sites More sharing options...
