Newton Posted September 17, 2016 Share Posted September 17, 2016 had my fuel tank sitting for a while as i worked on the comanche now that i put it back in the truck doesnt want to start ..it started after a good few swings but then shut off notice it was gettting any gas when i pressed on the accelerator after it shut off hasnt started since checked the pump i can hear it priming took the fuel rail out its not clogged or anything thinking it might be the injectors? after the pump is primed when i turn the ignition on and off like 2 times i won't hear it prime again like theres too much pressure in the line maybe the pump is bad?..any ideas? Link to comment Share on other sites More sharing options...
HOrnbrod Posted September 17, 2016 Share Posted September 17, 2016 rent a set guages from autozone or similar and connect them on the fuel rail test port turn on ignition and gauge pressure should read about 30psi if the pump is any good Link to comment Share on other sites More sharing options...
Newton Posted September 17, 2016 Author Share Posted September 17, 2016 ok i will test tomorrow thanks Link to comment Share on other sites More sharing options...
cruiser54 Posted September 17, 2016 Share Posted September 17, 2016 rent a set guages from Autozone or similar and connect them on the fuel rail test port turn on ignition and gauge pressure should read about 30psi if the pump is any good LOL Don..... Link to comment Share on other sites More sharing options...
