Jackrabbit41 Posted August 30, 2016 Share Posted August 30, 2016 So pretty sure my fly wheel is lose. If I'm pulling the tranny, I want to put in a better one. My current one leaks a lot and shifts bad. my question is, theres a lot of ax15s for sale but most without bell housing. I'm good to just swap on my current ax15 bell housing onto any ax15 right? like if i bought this, what do i need? I've done this swap before so i know how to do it. http://www.ebay.com/itm/1990-1999-JEEP-WRANGLER-4-0L-6-CYLINDER-4WD-5-SPEED-MANUAL-AX15-TRANSMISSION-/381692646575?hash=item58dea794af:g:tA4AAOSwLVZV1M4T&vxp=mtr Link to comment Share on other sites More sharing options...
88whitemanche Posted August 30, 2016 Share Posted August 30, 2016 Yea you'll be fine and that's an external slave ax15... Is yours external slave? I don't remember if you did or not.., Link to comment Share on other sites More sharing options...
Jackrabbit41 Posted August 30, 2016 Author Share Posted August 30, 2016 Yea you'll be fine and that's an external slave ax15... Is yours external slave? I don't remember if you did or not.., Yee it's external Link to comment Share on other sites More sharing options...
88whitemanche Posted August 30, 2016 Share Posted August 30, 2016 Yeah you'll be good just swap everything over... Since it's a wrangler ax15 the transfer case will be clocked upwards which is good for clearance for rock crawling... If it does interfere with the floor board a few wacks with a hammer will make due... Link to comment Share on other sites More sharing options...
Jackrabbit41 Posted August 30, 2016 Author Share Posted August 30, 2016 Yeah you'll be good just swap everything over... Since it's a wrangler ax15 the transfer case will be clocked upwards which is good for clearance for rock crawling... If it does interfere with the floor board a few wacks with a hammer will make due... Ok thanks I'll order tonight Link to comment Share on other sites More sharing options...
Jackrabbit41 Posted August 30, 2016 Author Share Posted August 30, 2016 Yeah you'll be good just swap everything over... Since it's a wrangler ax15 the transfer case will be clocked upwards which is good for clearance for rock crawling... If it does interfere with the floor board a few wacks with a hammer will make due... this one says its for all, will it be the same thing? just cheaper. http://www.ebay.com/itm/301673766523?item=301673766523&frommaketrack=true&viewitem=&vxp=mtr Link to comment Share on other sites More sharing options...
88whitemanche Posted August 30, 2016 Share Posted August 30, 2016 You won't know until you install the transfer case... Or unless they can prove that the back of that ax15 is clocked for both Cherokee/wrangler models... This is my ax15 on my truck that is from a 93yj....you see that the transfer clocked up...I have about 1/2" clearance from the transfer case to the floorboard with a couple hits with a hammer... Link to comment Share on other sites More sharing options...
Jackrabbit41 Posted August 30, 2016 Author Share Posted August 30, 2016 Sweet. Just called them. gonna be 1400$ with a $300 core. That's all my money lol. I've been saving for a dirt bike so that's not gonna happen Link to comment Share on other sites More sharing options...
