Megadan Posted September 8, 2016 Share Posted September 8, 2016 I have ElCheapo rubber mounts. 3 years strong and going. I think my application of Window Weld into the void between the rubber and the upper metal part of the bracket itself on the mout may have extended its life a bit. There was probably a good 1/4" of air gap before that. Link to comment Share on other sites More sharing options...
1989 comanche mj Posted September 9, 2016 Share Posted September 9, 2016 I have ElCheapo rubber mounts. 3 years strong and going. I think my application of Window Weld into the void between the rubber and the upper metal part of the bracket itself on the mout may have extended its life a bit. There was probably a good 1/4" of air gap before that. I like this idea! I put stock ones in after doing the clutch and seeing the originals were trash. Did you squirt it in after torqing them down or before? Link to comment Share on other sites More sharing options...
Megadan Posted September 9, 2016 Share Posted September 9, 2016 I have ElCheapo rubber mounts. 3 years strong and going. I think my application of Window Weld into the void between the rubber and the upper metal part of the bracket itself on the mout may have extended its life a bit. There was probably a good 1/4" of air gap before that. I like this idea! I put stock ones in after doing the clutch and seeing the originals were trash. Did you squirt it in after torqing them down or before? I Used a clamp to hold the two shells together and put a spare bolt through the hole to keep it aligned and layed it down on wax paper on a table and just filled it in from one side. It was a bit tedious because on mine it was a small gap. Let it set 24 hours, then undid it all. Before I did that though, I tried to clean them of any oil/grease with some dawn and hot water and let them dry. Link to comment Share on other sites More sharing options...
