Blinkers ain't flashin' boys
Are you sure you replaced the right flasher?
If the hazards flash, it shouldn't be a grounding problem.
I agree if your hazards are working then ground is fine. you have either a bad flasher for turn signal or something is shorting it across keeping the circuit constant.
Just a tip, if you have a manual and your clutch reservoir is leaking on the back of your fuse box under the hood, weird things like this can happen.
