Corydj69 Posted August 5, 2016 Share Posted August 5, 2016 I have a 4 cylinder 4 speed. l am having high idling problems. I need some insight on how to fix the problom. had the truck for 11 years, it ran great for a long time after I had it rebuilt Link to comment Share on other sites More sharing options...
cruiser54 Posted August 5, 2016 Share Posted August 5, 2016 The Idle speed actuator on the throttle body not retracting? Link to comment Share on other sites More sharing options...
HOrnbrod Posted August 5, 2016 Share Posted August 5, 2016 I have a 4 cylinder 4 speed. l am having high idling problems. I need some insight on how to fix the problom. had the truck for 11 years, it ran great for a long time after I had it rebuilt Do you have A/C? On the four bangers there is a switch on the power steering pump that bumps the idle up when cranking the steering wheel into the stops. The switch may be stuck closed. Disconnect the wire connector from this switch and see if the idle drops down. A leaking vacuum line will also cause a high idle. Check for disconnected and/or broken plastic vacuum lines. Link to comment Share on other sites More sharing options...
Zebvance Posted August 5, 2016 Share Posted August 5, 2016 I have a 4 cylinder 4 speed. l am having high idling problems. I need some insight on how to fix the problom. had the truck for 11 years, it ran great for a long time after I had it rebuilt Do you have A/C? On the four bangers there is a switch on the power steering pump that bumps the idle up when cranking the steering wheel into the stops. The switch may be stuck closed. Disconnect the wire connector from this switch and see if the idle drops down. A leaking vacuum line will also cause a high idle. Check for disconnected and/or broken plastic vacuum lines. I need this switch to help move my 35s Link to comment Share on other sites More sharing options...
Corydj69 Posted August 6, 2016 Author Share Posted August 6, 2016 Thank you for replying to my post. it had a.c. when I first got it. But I had to disconnect when I rebuilt the motor and I don't have power stearing. But l will look at the vac lines. Link to comment Share on other sites More sharing options...
Corydj69 Posted August 6, 2016 Author Share Posted August 6, 2016 The Idle speed actuator on the throttle body not retracting? Link to comment Share on other sites More sharing options...
