low side port 87 4.0
Hey gang
 so after reading the stories of AC's and R12a recharges i thought maybe id see if i could revive my AC -  but damn if i can't find the low side port - anyone point me in the right direction or have a pic of it? comanche's a stock 87 4.0 2wd w/ AC setup (of course!)
thx
 Mike
Ok so did you guys have to mess around with the adapter /add a elbow sort of deal -  -  i notice that when to put the adapter on the low side port from the R12a kit it effectively makes it so the spring adapter/coupler hose won't fit as the high side port is too close to the adapter part
thx!
mike
I saw a procedure on one of the Jeep forums where it showed that on the older systems, you have to do a little grinding with a Dremel tool on the HI side fitting for clearance. No problem for the 91's and up as the plumbing is laid out differently.
