My 88 MJ has come down with a case of death wobble, and we believe it's because of the track bar. Since I plan on lifting it 3"-4" within the next couple years, I was wanting to find an adjustable track bar that'll work for now and then. I've been looking around for an hour or so and can't find one that fits my needs. I was hoping someone could point me in the right direction.
I posted that since you said you plan on lifting it.  If you are at stock height, get a regular replacement track bar. They are pretty cheap, and most companies only make adjustables for 3+ because the factory one is generally fine for up just shy of 3"
Finding one good for up to 6" of lift that still works at stock height isn't easy. I wouldn't recommend Rusty's track bar to anyone but, before I learned the hard way, I bought one for my red '88 MJ when it had the 4" lift. With the lift, it worked fine -- except that it was a piece of junk. However, when I dropped it back down to stock height, the track bar was an interference fit with the front diff cover. I had to buy an OEM track bar before I could drive it again at stock height.
FWIW
