gte636p Posted May 30, 2016 Posted May 30, 2016 Title pretty much says it. I'm looking for the bracket to get the stock radio back where it goes. The bracket screws onto the radio and then into the dash, has a tab to hold the radio up against the dash. I am also looking for seat sliders for an XJ/MJ. I have swapped out to the buckets without flat bottoms. Unfortunately the drivers side was electric and the gears are broken in the slider assembly itself. Just looking for the stock slider frame for the seat now.
schardein Posted May 30, 2016 Posted May 30, 2016 For the seat sliders, not sure what you are looking for. I have several seats of XJ brackets, including the type that pivot/tilt back (the frame, not the seatback). They are all for the buckets that have the rounded bottom. However, the sliders don't come off easy, they are riveted on. Are you asking to have the sliders cut off the mount?
gte636p Posted June 5, 2016 Author Posted June 5, 2016 I know for sure the second picture is what I'm looking for. What I really "need" is the part that bolts to the seat frame itself so I can take the bracket that mounts to the floor and swap over my old MJ bench seat brackets. With that said, I should most likely rephrase and say the whole seat base would be more of what I am actually looking for.
