Heater Duct Gasket Material
I did a search and didn't find anything related, but I am re-doing the duct work on my Comanche, and I can't find any suitable foam material to use for the gaskets on the plenum doors.  What started all of this is that my heater core started leaking, so I had to remove the entire dash and everything related to replace it, so I thought I might as well re-do everything as long as I have it out.  Does anyone know where I can get some thin foam with an adhesive backing?
On a side note, I am also having to repair the passenger window regulator (manual).  I think I have found a source for the nylon tape gear, and I am going to try to just replace that.  I will let you know how that turns out.
Thanks in advance for the help,
Tom
