dana 44 pinion preload question
I'm working on installing 4.56 gears in the d44. I'm wondering about pinion preload how do I know if I need to shim the inner or outer pinion shims. Measured original shims then I Installed the same thickness with the new shims way too preload. Should I add to both stacks every time or just 1 at a time? Any help would be appreciated.
