does anyone know where this cable under passenger side dash connects to i think its for the vent or something
so if its not connected theres no hot air or cold air?...which of thh two?
^ yes it connects to the hot / cold lever
It connects to the back of the HVAC controls. #4 in the pic...........
Image Not Found
basically the door is in one direction, either cold or heat . I can't remember what direction is which on the box. I guess if it was not pulled all the way it could be in the middle. It is the flap for direction of air from the fan, either thru the heater core area, or bypass the heater core.
