Nofeartoys Posted April 24, 2016 Share Posted April 24, 2016 My MJ didn't come with a headliner like many other jeeps.The options are very low in this area of Comanche rebuild. Here is my way of doing mine repair. What I decided was to make a piece of wood fit in the indent channel of headliner area .I first made a piece out of 1/8 ish paneling to fit in the area and fastened to roof of the jeep along the lip (which has clearance to outside sheet metal). But after few days in mild temp that wood warped,good thing I didn't put Fabric on yet. So I trashed that and shaped a piece of 3/8 plywood to fit vehicle roof area. after getting proper fit and sanded wood I mounted my purchased dark grey headliner material . leaving 3in extra on sides 5 in front and 3 in rear past the edge of wood to glue to body and fill gaps. I mounted wood with fabrics to MJ cab with screw in locations where screw wouldn't touch outside roof sheet metal. I purchased screw cover patched from shelving isle at hardware store to help limit bulges in liner. Now gluing and trimming extra side fabric around cab I also made fillin panels for sides about 3 in wide and covered in same fabric and mounted behind trim panels. Using original metal clips on side to hold fill panels ground down visor mounts to help with gape ... Hopefully I did images right still learning Link to comment Share on other sites More sharing options...
Pete M Posted April 24, 2016 Share Posted April 24, 2016 I fixed the photos for ya. :thumbsup: you need to put the photos' address in the little pop up box (on a computer it is a little greenish box) is this part of a larger project thread or a standalone project for the DIY forum? Link to comment Share on other sites More sharing options...
Nofeartoys Posted April 24, 2016 Author Share Posted April 24, 2016 Thx for fixing pics. I use iPad. Don't use a computer Yes it's a ongoing rebuild. But prob. Could have put in diy. Link to comment Share on other sites More sharing options...
Pete M Posted April 25, 2016 Share Posted April 25, 2016 I'll move it over to the DIY for ya. :thumbsup: Link to comment Share on other sites More sharing options...
pitbull4x4 Posted February 16, 2017 Share Posted February 16, 2017 Looks good. Never thought about doing that Link to comment Share on other sites More sharing options...
Vivian Posted June 3, 2019 Share Posted June 3, 2019 Did you have more photo without fabric On 4/23/2016 at 10:02 PM, Nofeartoys said: My MJ didn't come with a headliner like many other jeeps.The options are very low in this area of Comanche rebuild. Here is my way of doing mine repair. What I decided was to make a piece of wood fit in the indent channel of headliner area .I first made a piece out of 1/8 ish paneling to fit in the area and fastened to roof of the jeep along the lip (which has clearance to outside sheet metal). But after few days in mild temp that wood warped,good thing I didn't put Fabric on yet. So I trashed that and shaped a piece of 3/8 plywood to fit vehicle roof area. after getting proper fit and sanded wood I mounted my purchased dark grey headliner material . leaving 3in extra on sides 5 in front and 3 in rear past the edge of wood to glue to body and fill gaps. I mounted wood with fabrics to MJ cab with screw in locations where screw wouldn't touch outside roof sheet metal. I purchased screw cover patched from shelving isle at hardware store to help limit bulges in liner. Now gluing and trimming extra side fabric around cab I also made fillin panels for sides about 3 in wide and covered in same fabric and mounted behind trim panels. Using original metal clips on side to hold fill panels ground down visor mounts to help with gape ... Hopefully I did images right still learning Link to comment Share on other sites More sharing options...
