Jackrabbit41 Posted April 3, 2016 Share Posted April 3, 2016 So Ive always wanted a roof rack, and headache rack, so I'm just wondering what y'all are runic? I mean more of the you built it stuff, cause ill be fabbin mine up. I love the look of them when they're are done right so hopefully I can do tha, but i also will use the headache rack as protection when hauling loads of steel and stuff like it. Id also like to put in some bed lights and a light bar on the roof rack. I'm just posting thing because Id love hear some ideas and see some pics. I can't find much on google images. Thanks also, ill build it so the roof rack will not be connected to the cab, it will be supported off of the headache rack, but I'll put the roof rack as low as possible because i hate seeing a gap in between the roof and the rack Link to comment Share on other sites More sharing options...
AMCJeepMJ Posted April 3, 2016 Share Posted April 3, 2016 Have you considered starting with a lumber/ladder rack for this idea? It should be easy to modify to suit your needs with some cutting/welding yourself or take it to a welding shop and spend $$ to have it done to your specs. Link to comment Share on other sites More sharing options...
Jackrabbit41 Posted April 3, 2016 Author Share Posted April 3, 2016 Have you considered starting with a lumber/ladder rack for this idea? It should be easy to modify to suit your needs with some cutting/welding yourself or take it to a welding shop and spend $$ to have it done to your specs. No matter what I'm doin it myself. I got a welder, cutting torch, tube bender, bandsaw, ect. Ill do it exactly how I want it. But that ladder rack is a good idea, it would be easy to change stuff around so I like it Link to comment Share on other sites More sharing options...
mikekaz1 Posted April 4, 2016 Share Posted April 4, 2016 especially if its a work related mod vs the "bro" truck look. id look into modifying a ladder rack or similar, as half the work is already done. this is a possible start http://www.harborfreight.com/automotive-motorcycle/truck-boxes-racks/800-lb-capacity-full-size-truck-rack-61407.html Link to comment Share on other sites More sharing options...
