pigg Posted March 29, 2016 Share Posted March 29, 2016 Hi everbody I need my MJ to get lower gears since I'm running 35"s and I'm gonna go for 4.88 in my axles. Rear axle is Dana 44 with OEM limited slip. Front is a Dana 30 HP from a 1996 XJ. Current gears in the axles are 3.54. What do i need to think about when I'm ordering rings and pinions for the axles? Do i need to change the carriers i both axles to fit 4.88? Please come with some input guys Link to comment Share on other sites More sharing options...
HOrnbrod Posted March 29, 2016 Share Posted March 29, 2016 For the D44 axle the carrier break is 3.73 which normally means a new carrier. But, you can keep your existing carrier by using "thick" 4.88 gears; they are available. I did this going from 3.55 to 4.10 because I had a new limited slip carrier and wanted to use it. Has worked well for many years now. For the D30 I think you are SOL because I've never seen "thick" 4.88 gears for them. They may exist though...... :dunno: Link to comment Share on other sites More sharing options...
pigg Posted March 29, 2016 Author Share Posted March 29, 2016 For the D44 axle the carrier break is 3.73 which normally means a new carrier. But, you can keep your existing carrier by using "thick" 4.88 gears; they are available. I did this going from 3.55 to 4.10 because I had a new limited slip carrier and wanted to use it. Has worked well for many years now. For the D30 I think you are SOL because I've never seen "thick" 4.88 gears for them. They may exist though...... :dunno: A thick 4.88 gear for my D44 would be awesome, never heard of that! Since it seems there is no 4.88 carrier that will fit my OEM limited slip, A THICK 4.88 WOULD BE A LIFESAVER!!! Any idea where i can get one???? Link to comment Share on other sites More sharing options...
pigg Posted March 29, 2016 Author Share Posted March 29, 2016 For the D44 axle the carrier break is 3.73 which normally means a new carrier. But, you can keep your existing carrier by using "thick" 4.88 gears; they are available. I did this going from 3.55 to 4.10 because I had a new limited slip carrier and wanted to use it. Has worked well for many years now. For the D30 I think you are SOL because I've never seen "thick" 4.88 gears for them. They may exist though...... :dunno: Found some thick gear kits on ebay, A W E S O M E ! This means i don't have to spend a fortune on an entirely new carrier and locker for the d44 and i can keep my beloved OEM lim slip!!!!! You made my day! Thank yoooouuuuu Link to comment Share on other sites More sharing options...
Incommando Posted March 30, 2016 Share Posted March 30, 2016 Link to comment Share on other sites More sharing options...
pigg Posted March 30, 2016 Author Share Posted March 30, 2016 Maybe you could use the money that you saved for a limited slip carrier for your D30. Thats exactly what I'm gonna do! Link to comment Share on other sites More sharing options...
