Iowamike Posted March 26, 2016 Share Posted March 26, 2016 Put a new ignition cylender in the 88 manche. After install and prior the key wouldnt come out. After i took the dash off there was a gray knob that poped out of the buttom of the column. So i pushed it in an the key comes out. Turn the key it pops back out, an the key won't come out. Is there some thing I'm missing? The column was out of a cherokee with tilt an works fine other then this knob / key problem. Link to comment Share on other sites More sharing options...
Iowamike Posted March 26, 2016 Author Share Posted March 26, 2016 After more reading. It looks like theres a linkage from the old jeep, it came from I'm guessing its an automatic wigit is there a conversion i got a 5 speed peugeot. Or do I just have to leave the dash apart to push it back in? Link to comment Share on other sites More sharing options...
64 Cheyenne Posted March 26, 2016 Share Posted March 26, 2016 I pulled it down wired it to release all the time. FWIW my column was swapped in from a newer Jeep but it had the release thing. Link to comment Share on other sites More sharing options...
Iowamike Posted March 26, 2016 Author Share Posted March 26, 2016 Ten 4 wired her up key works / comes out but now the dang thing doesnt shut off when the key is out unless clutch kill it Link to comment Share on other sites More sharing options...
Rockfrog Posted March 26, 2016 Share Posted March 26, 2016 it's the shifter interlock jobby. I disabled it while I was swapping lock cylinders before putting the 92 auto tilt column into my 88 5 spd MJ. can't remember what I did exactly, was a while ago. but pull the column, find the rod, figure out where it needs to be to let the key go and make that the permanent state. I think you just need to lock it in place. been a while like I said. Did you mess with the ignition switch rod at all? sounds like it's now out of adjustment or not connected correctly. Link to comment Share on other sites More sharing options...
Iowamike Posted March 27, 2016 Author Share Posted March 27, 2016 Nope just took the lock out. Its had this problem befor, I took the busted cylender out. I didnt change the column. So I'm guessing its on down the line of detective work. Learning as I go. Link to comment Share on other sites More sharing options...
64 Cheyenne Posted March 27, 2016 Share Posted March 27, 2016 I'd have to agree with the adjustment of the start switch rod, maybe the new key switch changed the "throw" of the rod. Link to comment Share on other sites More sharing options...
Rockfrog Posted March 27, 2016 Share Posted March 27, 2016 probably just slipped out of alignment while working on the other rod. Link to comment Share on other sites More sharing options...
