benjy_26 Posted March 21, 2016 Share Posted March 21, 2016 Hello all. I know this subject has been brought up in the past, and, having done research on the matter, I was set on ordering a pair of add a leaves from Hell Creek. Unfortunately, after placing my order, I received an email stating that they are no longer producing this item. Are there any alternatives to Hell Creek add a leaves, or should I just start saving now and buy their full leaf packs? Thanks in advance! Link to comment Share on other sites More sharing options...
ComancheKid45 Posted March 21, 2016 Share Posted March 21, 2016 How much lift are you looking for? Link to comment Share on other sites More sharing options...
benjy_26 Posted March 22, 2016 Author Share Posted March 22, 2016 I have 3" of lift in the front and was looking at around 2" in the rear, mostly to give the 31's I'm running a little more clearance, as they barely rub the flares when compressed (wide offset wheels). I'd also like my truck to sit close to level (I don't like a lot of rake). Link to comment Share on other sites More sharing options...
Eagle Posted March 22, 2016 Share Posted March 22, 2016 Rancho has an AAL set. They list the same kit for both the XJ and the MJ, so it's not quite a full-length under the MJ. It's good for about 1-1/2" in the MJ (2-1/2" in the XJ). Your other option is to roll your own using leafs from junkyard vehicles such as the older (spring under) Dakotas and S-10s. Link to comment Share on other sites More sharing options...
benjy_26 Posted March 22, 2016 Author Share Posted March 22, 2016 Thanks! I'll look into the Rancho set up. Have any of you guys heard anything about the Superlift long add-a-leaves? They're listed as giving 2" on our trucks, but zi bet that's on a XJ. Still, those combined with shackles should be ok, no? Link to comment Share on other sites More sharing options...
