So, while working with my interior lights yesterday I looked down and noticed the area around my door latch pin in severely cracked. If I wiggle the pin back and forth i can see the cracks open and close. It appears the body in this area has deteriorated to the point of cracking off. I can see no rust around this area and the passenger door does not have this issue. At 264k miles, i know this door has been shut, and probably shut hard for years. My question is, does anyone else have this issue, and if so is there a solution other than welding in a new section?
Thanks,
Mike.
One day I tried to close my door...it wouldn't close or latch.  So I started investigating, and found this:
So, after thinking about welding, taking it to a body shop, etc. etc.  I decided on this.  After I fished the striker out of the body B-pillar panel, I made a template out of cardstock, then cut out a piece of 16 ga. sheet metal.
I marked the striker position and drilled a large hole...about 1" IIRC...with a hole saw ( I thought there needed to be a big hole so I could move the striker around, to adjust it).  I flattened out the area where the striker goes and fitted up the sheet metal piece.  Then I drilled some holes for pop rivets, you could use sheet metal screws too, but I had 2 sizes of rivets and 2 rivet guns, this is how it looked then.
So then I slid the striker in there, and adjusted it to the door latch.  See the wiggle room in this shot:
So then I got it adjusted, touched up the paint and it's been like this for 2+ years
I was really surprised how easy it was to fix.  I was very concerned that I'd need to spend a buttload of $$.  But it worked out fine, and nobody can see it, nobody knows it's there but me (and all of you now)  Good luck however you decide to go.
I'm really into that repair. I may copy that, but before my door won't close haha. Do you have the dimensions of that plate you cut out?
Thanks,
Mike.
I never did really measure anything, I just traced the door jamb, and trimmed the template, and fit it, and trimmed again.  BUT since you asked, I went out and measured it.  So the top is 1 3/4"  The bottom is 2 1/4"  The measurement from top to bottom is 5 1/2".  The little jog towards the top just follows the contour of the door jamb, so it takes some cutting & grinding to get it just right.  An angle grinder with a cut off wheel, and another with a flap wheel really made it about a 15 minute job after I made the cardboard template.  The hole in the middle is 1",  A hole saw with a metal blade (aka hack saw) comes in handy too.
Deciding on rivets over sheet metal screws took about 4 hours :hmm:
