13 Legion Posted March 9, 2016 Share Posted March 9, 2016 Searched this topic already but still have a couple questions. Haven't drove my Comanche since October. It's an 87 2.5 4spd and it's stored in the garage. I went to start it in Dec and wouldn't start so I put it on a charger waited a few hours and fired right up. Today I went to start and same issue dead battery so it's back on the charger. Should I start up truck once a week or am I just better off disconnecting battery cables while storing? I just find it hard to believe an analog clock could sap the battery in a little over a month. Than again it could be something else all together. The battery is only 2 years old and I put maybe 500 miles on my truck last year. I had no starting issues prior to storing. Thanks! Link to comment Share on other sites More sharing options...
Pete M Posted March 9, 2016 Share Posted March 9, 2016 I disconnect mine. Link to comment Share on other sites More sharing options...
Gene Posted March 9, 2016 Share Posted March 9, 2016 Hi Legion, Two things happen: 1. Batteries slowly discharge, even with no external drain. This will be less of a concern in cold weather, more in hot. 2. There is always a little drain into the vehicles electrical system. The clock will be a minor drain, the original radio in my 88 had a bit more drain as well. It doesn't have to be much to drain a battery over weeks of sitting. So: 1. Disconnect the ground cable if the vehicle will be sitting (I use a week or longer as "sitting") 2. Charge the battery about once a month, even if disconnected. Discharged batteries will age (sulfation) faster than charged batteries. Gene Link to comment Share on other sites More sharing options...
13 Legion Posted March 9, 2016 Author Share Posted March 9, 2016 Thanks for the input guys! I'm definitely gonna disconnect the battery when I store again. Link to comment Share on other sites More sharing options...
buckwheat Posted March 9, 2016 Share Posted March 9, 2016 Check out a battery disconnect switch. Instead of taking off and having to re-install the negative cable you can just flip a switch to "disconnect" it. Couple of different types available. Could make your life a lot easier. Link to comment Share on other sites More sharing options...
