ARareBreed Posted March 4, 2016 Posted March 4, 2016 This question is for seasoned vets. I have a Comanche with 5.5" lift, HP Dana30, jks2001 quick disconnects and currie 9701 steering system and clayton long arms and stock pitman arm. My caster is dialed in, wheels are properly centered in the wheel well and when turning right the center tre hits the passenger sway bar mount. I found this, see link below.... http://www.synergymfg.com/Synergy-Su...n-p-21291.html I like this setup, its obvious I need to brush up on my welding. The real question is, since I have adjustable sway bar links do I need to do this on both sides of the axle? The driver side is fine with the stock mount off the axle. Is it okay if the links are different lengths?
shelbyluvv Posted March 4, 2016 Posted March 4, 2016 A drop pitman arm and track bar bracket will fix it the right way
ARareBreed Posted May 16, 2016 Author Posted May 16, 2016 I got the bracket only on the passenger side, have about 1,000 miles on the truck since the install and it hasn't given me any troubles.
