LaComanche88 Posted February 18, 2016 Share Posted February 18, 2016 Please help... I installed a new clutch kit on my 88 comanche so I wanted to bleed my hydraulic throw out bearing since it was new and I was eager to do it so I used a hose I had going from the manifold to the egr solenoid. after I rinsed and let it sit for a day...first try to start and it turmed on. while on I plugged in the hose I used and then it shut off now it won't start can anyone help pleae thank you Link to comment Share on other sites More sharing options...
87MJTIM Posted February 18, 2016 Share Posted February 18, 2016 Did you reconnect the CPS? Maybe knock off the wire for the CPS. Link to comment Share on other sites More sharing options...
LaComanche88 Posted February 18, 2016 Author Share Posted February 18, 2016 Yea it was connected I got it to start then when I plugged in the hose I used to bleed it it, it shut off and then wouldnt start like if the hose had oild still from the bleed? Link to comment Share on other sites More sharing options...
HOrnbrod Posted February 18, 2016 Share Posted February 18, 2016 Sounds like you sucked clutch fluid from the EGR hose into the intake and maybe gummed up your injectors. Pull your plugs and see what they look like. Hopefully you can clean/dry them up and it will start and blow the crap out. Link to comment Share on other sites More sharing options...
LaComanche88 Posted February 18, 2016 Author Share Posted February 18, 2016 So I have to reove my fuel rail and all ? Link to comment Share on other sites More sharing options...
LaComanche88 Posted February 18, 2016 Author Share Posted February 18, 2016 Or clean the manifild or ? Link to comment Share on other sites More sharing options...
HOrnbrod Posted February 18, 2016 Share Posted February 18, 2016 Just try pulling the spark plugs first....... Link to comment Share on other sites More sharing options...
