I replaced my b pillar lights with some new euromatic ones. They work great most of the time, but sometimes they seem like they get no power. They don't turn on from door switch or manual switch on the light, and it's both lights not working. When this happens the other floor lights are working and the fuse seems good.
That makes me think power, since likely both grounds wouldnt stop working?
I'm thinking about pulling drivers side panel and looking over wires.
This happened to anyone else?
Common connector is c118 voltage feed and G102 ground.
C118 is located behind the driver's side kick panel.10 pin connector.
G102 is located on the driver's side inner fender.
Both the ground and power for the lights go through C118......
