Wanted Arm Rest Parts
1992EliminatorSWB4x4
I would like to buy the armrest attach to door parts, I only need The  armrest mounting nipple, a whitish plastic/nylon part with the square hole that inserts into the door, then a metal clip goes into that piece by inserting it in the square hole. These parts hold the armrest upper stud that is flat on two sides to the door. My lower bottom two screws and inserts are ok, so only need the upper stud parts. Mopar lists Part# J3077045 as the whitish nipple insert,  and J3076062 as the metal clip that actually grips the upper armrest stud. Help !!!   For my drivers side door,  the passenger door side is ok.
Bill
