Just installed new clutch kit, slave cylinder, and master cylinder. I have bled the system but still does not feel right. Clutch feels good when not running , but when started it is not so good. Pretty sure I bled it out good, but it is still hard to get in gear sometimes. Noticed the other day that when i was facing downhill it was harder to get in gear. Any help would be appreciated.
Try this:
Pump the clutch pedal about 40 times and walk away for 10 minutes.
Don't think I can get the rear end that high.
Try this:
Huh?
Thought you meant jack the rear end up like that in your pic and pump it 40 times. Cause I have read somewhere when bleeding to raise the rear end up higher and I didn't try that.
Try this:
Huh?
Nah. Just sit in it and do that. LOL.
Try this:
Huh?
I will try that then. By the way is that your MJ in your signature? If so what year and model is it and what kind of mods have you did?
That's one of my MJs. #16.
I had 13 of them as demos at the dealership and have owned 3, still have 2.
3" lift is about it. I bought it in very poor condition.
My 90 is really nice.
