Wiper will not work.
My wipers are not working and I just replaced the wiring switch behind the steering wheel. I replaced the wiring for the turn signals, brake lights and all. The wipers worked and all of a sudden the wipers don't work. Anyone tell me what to do please?
There is no fuse for the wipers. Instead their is a circuit breaker. When the wipers on my 86 failed to work, I discovered the two blades going into the circuit breaker were corroded. Light sanding and steel wool cleaned it up and I was back in business.
The wipers circuit breaker is a silver colored thing plugged into the fuse box under the dash.
yep yep, mine kept messing up and I kept thinking it was the delay module turns out it was that circuit breaker being a bit corroded from our good friend mister master cylinder leaking some lovely brake fluid onto the back of the fuse panel =[
