1992EliminatorSWB4x4 Posted November 12, 2015 Share Posted November 12, 2015 Inside the 1992 Saginaw tilt steering column, below the turn signal assembly, there is a white nylon bar with 2 copper flat short metal bars attached to that near the ignition lock switch assembly, the function of it is to activate the lock warning buzzer, if I leave that out will the buzzer just remain silent, or will it buzz all the time ? Link to comment Share on other sites More sharing options...
Comanche County Posted November 12, 2015 Share Posted November 12, 2015 Leave it in, just pull the buzzer from the fuse block. Link to comment Share on other sites More sharing options...
HOrnbrod Posted November 12, 2015 Share Posted November 12, 2015 Thar's the key-in-ignition chime. It activates the chime module if the key is in (obviously) when you open the door. W/o the link activated by the ignition switch, it won't do anything. And keep the chime (buzzer) module. It's saved my bacon a few times when I left the headlamps on. Link to comment Share on other sites More sharing options...
1992EliminatorSWB4x4 Posted November 12, 2015 Author Share Posted November 12, 2015 Thank You fellows. The reason I asked was below my device the clip spring is broken, Jeep dealer and Chevy GM dealership says item is discontinued. I will go to the pull apart junkyard and try to get that spring tomorrow. My ignition lock cylinder fell apart yesterday and I was replacing the lock cylinder with a new one and discovered that issue, and also the torm screw/bolt that holds the lock cylinder in place was missing, so pull a part here I come. I will get it all back together tomorrow I hope, its all apart tonight. Link to comment Share on other sites More sharing options...
