Newton Posted October 29, 2015 Share Posted October 29, 2015 MJ idling fine when started but stalls after high rev rpm drops low and stalls I cleaned iac checked vacuum lines no leaks that I know of any help as to why it's doing that would be greatly appreciated Link to comment Share on other sites More sharing options...
cruiser54 Posted October 30, 2015 Share Posted October 30, 2015 On 10/29/2015 at 10:18 PM, Lylonbag said: MJ idling fine when started but stalls after high rev rpm drops low and stalls I cleaned iac checked vacuum lines no leaks that I know of any help as to why it's doing that would be greatly appreciated Of my tips listed below in my signature, how many have you completed? Link to comment Share on other sites More sharing options...
Newton Posted October 30, 2015 Author Share Posted October 30, 2015 On 10/30/2015 at 3:09 AM, cruiser54 said: On 10/29/2015 at 10:18 PM, Lylonbag said: MJ idling fine when started but stalls after high rev rpm drops low and stalls I cleaned iac checked vacuum lines no leaks that I know of any help as to why it's doing that would be greatly appreciated Of my tips listed below in my signature, how many have you completed? Haven't done everything in your tips I've cleand iac refreshed grounds new vacuum harness new cps haven't tested tps but ordered a new one should get it on the weekend haven't refreshed coil u have a lot of tips is there any in particular that could be a cause of my problem or should I start working on your tips 1 by 1? Link to comment Share on other sites More sharing options...
cruiser54 Posted October 30, 2015 Share Posted October 30, 2015 On 10/30/2015 at 3:41 AM, Lylonbag said: On 10/30/2015 at 3:09 AM, cruiser54 said: On 10/29/2015 at 10:18 PM, Lylonbag said: MJ idling fine when started but stalls after high rev rpm drops low and stalls I cleaned iac checked vacuum lines no leaks that I know of any help as to why it's doing that would be greatly appreciatedOf my tips listed below in my signature, how many have you completed?Haven't done everything in your tips I've cleand iac refreshed grounds new vacuum harness new cps haven't tested tps but ordered a new one should get it on the weekend haven't refreshed coil u have a lot of tips is there any in particular that could be a cause of my problem or should I start working on your tips 1 by 1? 1,3,4, and 5 are the foundation. Link to comment Share on other sites More sharing options...
Newton Posted October 30, 2015 Author Share Posted October 30, 2015 On 10/30/2015 at 12:22 PM, cruiser54 said: On 10/30/2015 at 3:41 AM, Lylonbag said: On 10/30/2015 at 3:09 AM, cruiser54 said: On 10/29/2015 at 10:18 PM, Lylonbag said: MJ idling fine when started but stalls after high rev rpm drops low and stalls I cleaned iac checked vacuum lines no leaks that I know of any help as to why it's doing that would be greatly appreciated Of my tips listed below in my signature, how many have you completed?Haven't done everything in your tips I've cleand iac refreshed grounds new vacuum harness new cps haven't tested tps but ordered a new one should get it on the weekend haven't refreshed coil u have a lot of tips is there any in particular that could be a cause of my problem or should I start working on your tips 1 by 1? 1,3,4, and 5 are the foundation. Thank you I'll get to it Link to comment Share on other sites More sharing options...
Newton Posted November 3, 2015 Author Share Posted November 3, 2015 i tried cruisers tips also put in brand new new tps iac still no luck i read somewhere else it could be transmission solenoid...any one can relate to that? Link to comment Share on other sites More sharing options...
cruiser54 Posted November 4, 2015 Share Posted November 4, 2015 On 11/3/2015 at 11:20 PM, Lylonbag said: i tried cruisers tips also put in brand new new tps iac still no luck i read somewhere else it could be transmission solenoid...any one can relate to that? What were the results of Tip 5? Link to comment Share on other sites More sharing options...
