n4ter Posted October 4, 2015 Share Posted October 4, 2015 I have the old doors from my 89 mj and I'm Looking at removing the glass and mec., so I can scrap the metal. Link to comment Share on other sites More sharing options...
Crash Posted October 4, 2015 Share Posted October 4, 2015 Pull the panels off, remove the bolts from the "window isolators". Hopefully manual or rolled at least part way down. After that ther eare a few bolts for the vent window/front window track. Should be about 3 bolts holding in the window regulator, whether power or manual. If all else fails, use a rock or brick for the glass and clean up with a shop vac. Link to comment Share on other sites More sharing options...
n4ter Posted October 10, 2015 Author Share Posted October 10, 2015 Thanks. Ill try to get the glass out in one piece. Link to comment Share on other sites More sharing options...
Jrwhite3230 Posted October 12, 2015 Share Posted October 12, 2015 after clearing all the trim and the trim clamps sit inside the truck and put foot on windoshield and kick that sucka out ! being extra carfull you must where protective clothing eye gogles face shield and gloves ! you must take a piano or heavey guitar strings to cut away the rubber caulking around windshield first and then proceed to push out windshield ! Link to comment Share on other sites More sharing options...
ComancheFan1991 Posted October 13, 2015 Share Posted October 13, 2015 after clearing all the trim and the trim clamps sit inside the truck and put foot on windoshield and kick that sucka out ! being extra carfull you must where protective clothing eye gogles face shield and gloves ! you must take a piano or heavey guitar strings to cut away the rubber caulking around windshield first and then proceed to push out windshield ! He wants to remove the door glass, not the windshield. Link to comment Share on other sites More sharing options...
