ComancheFan1991 Posted October 2, 2015 Share Posted October 2, 2015 What are the symptoms of a bad or out of adjustment Renix TPS? Do the symptoms include not returning to idle when the accelerator isn't pressed? Link to comment Share on other sites More sharing options...
Crash Posted October 3, 2015 Share Posted October 3, 2015 Sounds more like a linkage and/or iac problem. But, I supposed if the TPS is FUBAR'd enough, then maybe. Link to comment Share on other sites More sharing options...
cruiser54 Posted October 4, 2015 Share Posted October 4, 2015 What are the symptoms of a bad or out of adjustment Renix TPS? Do the symptoms include not returning to idle when the accelerator isn't pressed? High idle on start-up is the most common issue. Link to comment Share on other sites More sharing options...
mik666 Posted October 4, 2015 Share Posted October 4, 2015 my symptom (my TPS went bad just last week) was a bad hesitation when you stepped on the gas from idle - it would die if you didn't do it slowely Link to comment Share on other sites More sharing options...
