1992EliminatorSWB4x4 Posted September 29, 2015 Share Posted September 29, 2015 My 1992 jeep Eliminator has a 1995 Mopar Oil Pan tag on the decal sticker attached to the oil pan. To the right of the distributor on top of the engine short block it has these numbers, I 39 MX I6 stamped into the engine. Is this a 1992 engine, I do know it is an H.O. engine. Thanks. Bill from Alabama Link to comment Share on other sites More sharing options...
Eagle Posted September 30, 2015 Share Posted September 30, 2015 Engine codes: 1st digit = year (8=1998, so 1 =1991) 2nd & 3rd digits = month (01 - 12) 4th & 5th digits = Engine type (MX = 4.0L, HX = 2.5L) 6th & 7th digits = Day of build (01 - 31) From 2000 FSM Link to comment Share on other sites More sharing options...
1992EliminatorSWB4x4 Posted September 30, 2015 Author Share Posted September 30, 2015 Thank you, for the info. Guess mine just has a newer oil pan, must have been changed, at least its a Mopar pan. Link to comment Share on other sites More sharing options...
JH4020 Posted November 26, 2015 Share Posted November 26, 2015 The digits on a motor I have read 104C03. What does the "C" stand for? Link to comment Share on other sites More sharing options...
Area51Werks Posted November 27, 2015 Share Posted November 27, 2015 Thanks for the info. My 91 had an engine swap. Very stock job under the hood. If I hadn't have been told it was swapped I would have never known. The block shows the first number is 5 and it is an MX so that's good right? Did they have the HO engines in 95? Link to comment Share on other sites More sharing options...
gogmorgo Posted November 27, 2015 Share Posted November 27, 2015 All '91+ can be considered HO's, although they were only OBD1 until '96(?). '95 will be pretty well the same as a '91 with a couple small changes. Link to comment Share on other sites More sharing options...
