New to your Forum with questions
I was told the linkage from the driver side to the passenger side was broken. Only the driver side is working. Just wondering if this is common and if there are any other common items to look out for. The truck is across the country. I have to hop a plane to go get it. Just want to be smart about other things to look for when inspecting.
If replacing the plastic bushings doesn't fix it, it's easy to remove the whole assembly (you will do that anyway, to replace the bushings), and the wiper assembly is the same as a Cherokee so a junkyard replacement should be easy to find.
  • 4 weeks later...
