ComancheFan1991 Posted September 24, 2015 Share Posted September 24, 2015 I'm new to the Comanche. Don't have one yet. I'm wondering what areas of the vehicle should be bedlined for longevity. I know that the floor of the cab, the insides of the rocker panels, as well as both the inside and underside of the bed, should probably be bedlined. Also is it safe to put the bed on grass upside down or will it spread out, at least at the tail gate end. Link to comment Share on other sites More sharing options...
91Pioneer Posted September 24, 2015 Share Posted September 24, 2015 Bed liner is not the same thing as rust proofing. If you're worried about rust, use an oil-based rustproofing product. If you plan on throwing a bunch of rocks gravel lumber etc. on your floorboards then go ahead and use bedliner. Link to comment Share on other sites More sharing options...
ComancheFan1991 Posted September 25, 2015 Author Share Posted September 25, 2015 Would the bedliner be better protection against rocks and such on the road? Link to comment Share on other sites More sharing options...
91Pioneer Posted September 25, 2015 Share Posted September 25, 2015 Bed liner belongs in the bed only IMHO (unless you're doing some crazy off-roading). Link to comment Share on other sites More sharing options...
87Warrior Posted September 25, 2015 Share Posted September 25, 2015 Fix the rust and you won't have any problem with a properly applied quality paint. Bedliner will do a great job hiding rust behind its hard shell. Link to comment Share on other sites More sharing options...
ComancheFan1991 Posted October 5, 2015 Author Share Posted October 5, 2015 So what would you recommend for use under the carpet after all rust is removed if any is found, as paint only seems to last 10 years under carpet in NY? Did they use a "tar" sound deadener under the carpet as well? We redid the floor of my dad's 2005 Scion xB this Spring because of surface rust, and the tar based sound deadener that Toyota used, like to stick to the surface rust better than to solid paint. It took a propane plumbers torch and a putty knife to get it out of the driver's footwell, which where the surface rust was, but I could remove most of the rest of it with my bare hands. We did remove the drain plugs and used the Rust-Oleum bed liner in a spray can, two coats in the back and three in the front, and reinstalled the plugs with silicone caulk around the lip, to keep the water and salt out from outside coming in. Link to comment Share on other sites More sharing options...
