Bench seat slider parts issue
Hello, I have an '89 that I took out of service and it has been in my garage for over a year now. Turns out that I'm doing way more work than I anticipated, but loving every minute of it. So, the bench seat is missing a part, been that way since I purcased from po. Seems to be that there should be a heavy gauge wire from the driver side adjuster lever to the passenger side spring lock (for the seat adjustment). There is a tab with a hole on the lever, however I can not find anything on the passenger side that looks like the spot for the other end that would work. I'm hoping that somebody has access to a bench seat and is able to send a photo of this detail so I can figure this all out. Thank you in advance, can't wait to get my MJ back on the road!
Thank you. Looks like the one and obvious spot is a hole that is shared with a spring. And I will use an S hook to support the wire from sagging,as per the detail you sent me. That should do it. Will be painting body parts and on the road/trails soon.
According to the parts manual, two "S" hooks are required on the adjustment wire even though it only shows one.
I have a grey bench seat complete. No tears, everything is in good working condition. I converted my truck to buckets seats and console and no longer need the seat.
I had the seat listed on Craigslist a few months ago for $75.00. A reasonable offer would be accepted.
Westminster, MD
