Paul Bruchal Posted September 3, 2015 Share Posted September 3, 2015 I been looking for along time and can't find anything on this. When having hood vents installed, and it rains, could the rain mess up anything on the engine, sensors like TPS, electronics? In not worried about cutting holes in my hood, just worried about the rain under the hood. I'm about to install some hood spacers and Maybe 2 vents. Where should the vents go on the hood? near the rear of the engine? Link to comment Share on other sites More sharing options...
HOrnbrod Posted September 3, 2015 Share Posted September 3, 2015 http://gojeep.willyshotrod.com/HowtoBonnetVents.htm Link to comment Share on other sites More sharing options...
Paul Bruchal Posted September 4, 2015 Author Share Posted September 4, 2015 would the rain rust the engine? Link to comment Share on other sites More sharing options...
HOrnbrod Posted September 5, 2015 Share Posted September 5, 2015 would the rain rust the engine? No worries if a little rain gets in while you're driving as the hot engine will boil off the water quickly. And you don't want your vents directly over the distributor, throttle body, or other sensitive areas. When parking at night outside in the rain you can cover the vents with a couple of pieces of flexible magnetic sign material to keep the H2O out.. Link to comment Share on other sites More sharing options...
ComancheKid45 Posted September 5, 2015 Share Posted September 5, 2015 I used an old roll up sled to make guards protecting the distributor and throttle body sensors under my vents. Link to comment Share on other sites More sharing options...
