odd clunk?
Installed a new set of leaf springs and shackles. Now the passenger side when I drive randomly (but normally on bumps) makes a HARD clunk noise. If I'm parked and jump up and down in the bed, Nothing. If I grab the bedside and shake it, nothing.
Everything's snug.... is it possible things are too snug? Anyone run into this before?
exhaust is solid. i have the front leaf mount  and frame shackle at 100ft/lb  and rear eyelet at 80ft/lb and all u bolts beyond my torque wrench capabilities. (which i think are the factory specs)
but i think i may have found it.... i think my shock is maxing out.     between the ~2" lift the springs gave and the extra thickness of the spring pack ~1"  i think I'm just over exteding the shock. although i havent verified this.
