Speedometer not working and the gas gauge not working
  • 1 month later...
I would check all of the electrical connections between the sensors and the cluster, as the '91s and the '92s used an all electronic cluster. The connections at the cluster might be the problem. My parents had a '91 XJ that a speedometer that didn't work intermittently, and a fuel gauge that read with the key in the lock position. I personally would try whacking the top of the dash above the cluster, as that may get the speedometer working at least briefly, if it's a loose connection there.
