I need a broken MJ OR XJ fuel sender from the model years 1986 to 1992. It does not matter if from a short or long bed tank, as all I am going to use is the actual lid (which covers the hole in the tank). None of the other parts need to work, or even be in good shape EXCEPT for the cap. Obviously, if your broken sender is rusted through the cap I cannot use it.
I am installing a new tank in Junior with a Genright fuel sender ring and 2000 XJ sender. I need the cap to seal the hole on the side of the tank, and will be welding it in (and welding shut the wiring holes and pipe openings)
Please let me know how much you might want for it, and where you are (zip code) so I can calculate shipping.
I *think* I can send you a non-functioning MJ SB one for the cost of shipping. I just need to dig around in the shed but I'm pretty sure I've got it and didn't throw it out.
You are correct, but I wonder...is the diameter of the cap the same regardless of the tank size? This one is a great price but lists for the 13 gallon tank (which I have never even heard of let alone seen)
Good question , the part number is 5252048 . I bet if you look up the part numbers of the lock ring and if they are the same the diameter will be the same .
