ARareBreed Posted August 13, 2015 Share Posted August 13, 2015 I'm in the process of swapping my 4.0 2wd drivetrain to the 4wd drivetrain in my newly acquired MJ. Other than the obvious front axle, drive shafts and transfer case, it has an AX15 from the factory and I found a 4.0 1996 AX15 external slave from an XJ donor. I know the input shaft from the 1991 AX15 is .59" and the input on the 96 AX15 is .75". So I got a new pilot bushing from and early 70's CJ, P/N PB77HD. My question is, I want to replace the clutch while I'm in there. I am going to get a clutch from the 1996 trans, P/N: LuK 05-901. I also want to change out the flywheel (P/N: LuK LFW193), do I need to get a 1991 flywheel or a 1996 flywheel? Do I need to worry about the tone rings or anything like that? How about aligning or adjusting the clutch? Never done that before either. Another thing I am thinking about is a flywheel shim, Will I need a shim when replacing the flywheel completely? Link to comment Share on other sites More sharing options...
The_outoors Posted November 5, 2015 Share Posted November 5, 2015 Did u ever get answers because I need to figure out everthing u just asked Link to comment Share on other sites More sharing options...
gogmorgo Posted November 6, 2015 Share Posted November 6, 2015 Use the flywheel for whatever year your CPS and/or ECU is. The difference is how it reads the windows on the flywheel. '91 and '96 may be the same since they're both HO's, but I don't actually know. The CPS part numbers are different, but it may just be the wiring connector. Link to comment Share on other sites More sharing options...
FrankTheDog Posted November 6, 2015 Share Posted November 6, 2015 What year is the MJ you are putting this all in? 1991? Link to comment Share on other sites More sharing options...
