Stereo electrical question
The wiring in my MJ is... ruined, from last owner. Do yall think it would be alright for me to directly wire the stereo a constant 12v and ground, and just turn off the stereo when not using it? The last owner had something rigged up like that.. the little red light was on 24/7 and all you had to do was hit the power button to listen. No keys required.
If yall think I should try to wire it the right way. Could someone please show me a wiring diagram for a 1988 MJ that you used. I been looking at different diagrams all morning and they are all different.
I think that you will need a diagram to wire proper anyways, but in my XJ I have the constant/"ign" power wires together running to the constant (which IIRC is the pink wire) with an inline fuse. Your HU might have a fuse in it, if not definitely run an inline fuse. I always detach the face, which cuts power to the HU. SO that is fine.
