I was cleaning my ignition coil while going through the cruiser tips.
I noticed first the ECU has 3 connections on it, but only two are hooked up, I assume the 3rd is not supposed to be hooked up since no cable is around unplugged?
Also, the ignition coil has two stud connections and one terminal, I don't see that the terminal connection would connect to anything?
Then on top of the ECU, should I bend the tabs out some to help with the connection?
Lastly I read there should be springs, but mine had no springs, where should those go and how?
I think I figured it out...  I was looking for an actual spring, but it's just to bend the little tabs out and make them closer...
done!
