Advice for Frankenstein.
I t-boned a mini van yesterday and totalled my COMANCHE in the front. no apparent damage behind the a pillar as of yet (havent gotten it from the yard)
1990 SWB 4.0L 2wd
I also own a 1989 SWB 2.5L 2wd that is rusted so bad there is a 20 inch seam opening around the front knuckle of the driver side leaf spring (started its life in Iowa)
I will be pulling parts from the 90 to make the 89 a little safer (both of the leaf springs have cracked and are u bolted back together)
How do I put my ax-15 behind the 2.5?
Should I take the gears out of my 4.0 rearend? easier to swap rear ends if I am taking off the springs? All of this will be done in a gravel driveway, YAY
What else should I consider taking off of the 4.0? I don't think I am ready to preform a swap but have been considering storing the 4.0. Problem is I already have a 350 on my engine stand that I need to get rid of
