No Guage Lights!
when i turn my lights on at night my outside lights go on but no guage
lights do. my idiot lights and blinkers work. i checked the light switch,
fuse on fusebox, and speedo. everything looks good. i put a new speedo
in and still have the problem. does anyone have any idea on what it could
be? the more i think about it the more i get mad.
my truck is a 2wd 1988 shortbed automatic 4.0L if that helps
THANK YOU,
Sean
Have they ever worked?
I thought i had this problem. Really I just didnt understand the switch. Turn the knob counter clockwise as far as it will go. Your interior lights will come on. Then just back it off a bit clockwise and then your gauges will be lit up.
Hopefully its just that.
THANK YOU,
Sean
Why get mad? If the switch works, and the fuse is good, then it's gotta be a simple wiring problem (probably from the hot side). Look at a wiring diagram, and think about where the commonality is if all the panel lights are dead, then the answer should be clear.
I had a problem like this that took me about 45 minutes to figure out that I had turn the pull knob for the lights and dimmed them out. :dunce:
Since you said you checked the switch, I'm assuming you checked that too. Could be the connection on the back of the instrument panel is not seated all the way.
:cheers:
