Sir Jacob the 2nd Posted July 9, 2015 Posted July 9, 2015 Well gents I bought my MJ about a year ago and started noticing a few things that needed work. So I started in on those and found a large list of things that the PO screwed up, and so began my rebuild. And it all started with a/c repair haha. Will be posting some pictures here shortly, as soon as I can work out exactly how
Sir Jacob the 2nd Posted July 10, 2015 Author Posted July 10, 2015 Well here she is, my MJ long box. It's a bit rough around the edges but all in all not in bad shape. I think the farthest north it has been is South Carolina according to the PO so minimal rust which is always good.
Sir Jacob the 2nd Posted July 10, 2015 Author Posted July 10, 2015 started to break things down yesterday, making pretty good progress for my limited time.
relyt120 Posted July 10, 2015 Posted July 10, 2015 Awesome, love column shift. Those mirrors or huge!
Sir Jacob the 2nd Posted July 10, 2015 Author Posted July 10, 2015 Awesome, love column shift. Those mirrors or huge! Awesome, love column shift. Those mirrors or huge! Yeah haha the PO was going to try and tow his boat with it . So he screwed those ugly things in there and glued plastic plates over the OEM mirror spots
Sir Jacob the 2nd Posted July 13, 2015 Author Posted July 13, 2015 Made a bit more progress stripping down the MJ yesterday just a bit more and I'll be ready to pull the engine.
relyt120 Posted July 13, 2015 Posted July 13, 2015 How did you realize it was a JY swap? I also found out, much to my dismay that the motor that is in the truck is not the original motor, it is a motor from a junk yard. This wouldn't be so irritating had the PO not lied to me and told me it was original. but I guess at this point it doesn't matter because I'm not trying to factory reset the truck or anything.
Sir Jacob the 2nd Posted July 13, 2015 Author Posted July 13, 2015 Well for one thing the serial numbers on the block don't match the catalyst and two it had been spray painted with white paint to mark it at the yard. I don't recall what it said now. But the block had caked on oil when I bought it because of some significant leaks so the writing was covered. And now as I was cleaning it off, I found it
Sir Jacob the 2nd Posted July 17, 2015 Author Posted July 17, 2015 Started breakin down the block, Off to the machine shop she goes!
Sir Jacob the 2nd Posted July 17, 2015 Author Posted July 17, 2015 Also was able to begin sanding and prepping to prime and paint the engine bay... Stupid rain once again holding me back. But slowy making progress
buxmj Posted July 17, 2015 Posted July 17, 2015 Great work, keep the posts coming! Yeh this fl afternoon rain everyday can really screw with getting stuff done, good luck. Buck
Sir Jacob the 2nd Posted July 18, 2015 Author Posted July 18, 2015 Thanks will do! Yeah unfortunately the afternoons are about the only time I have available to work on it, but I'll make do
Sir Jacob the 2nd Posted February 3, 2016 Author Posted February 3, 2016 So it has been some time since I posted here last and a lot has happened so I'm going to try to catch up! So I got my block and head back from the machine shop and started the process of putting it all back together.
Sir Jacob the 2nd Posted February 3, 2016 Author Posted February 3, 2016 My new pistons and rod bearing getting ready to go in, I did however reuse my rods as, looking them over all being in good shape I saw no reason to spend the extra 500 dollars or so. I went ahead and had the crank micropolished while my block got decked and bored just to dot the i's and cross the t's. Side note I went .030 over in the cylinders I think I forgot to mention that earlier. Also reused my main caps. The machine shop "lost" one in their mess of a shop. Luckily they mostly deal with performance imports, not a ton of cast iron laying around elsewhere.
Sir Jacob the 2nd Posted February 3, 2016 Author Posted February 3, 2016 Finished painting my engine bay, it's not perfect or professional but it gets the job done!
Sir Jacob the 2nd Posted February 3, 2016 Author Posted February 3, 2016 Took some parts to work to use the parts cleaner valve cover along with misc brackets and what not. Cleaned up pretty well.
Sir Jacob the 2nd Posted February 3, 2016 Author Posted February 3, 2016 All going back together now and painting. Here she is!
Sir Jacob the 2nd Posted February 3, 2016 Author Posted February 3, 2016 The water pump and thermostat housing you see in the above picture ^ i got from HESCO it's the highflow water pump with upgraded impeller and ported Tstat housing in case you were wondering.
Sir Jacob the 2nd Posted February 3, 2016 Author Posted February 3, 2016 Got A few goodies in, Also bought a new evaporator core and heater core. As you can see in the pictures the new one is slightly different than factory. Because of this I had to make some slight modifications to the air box because of the orientation of the tubes in the new evaporator core
